Hello. I need some help. I have a 2015 Polaris rzr 1000. I was told the clutch was bad so I put a new one in with a new belt and having the same problem. It won’t go over 55 mph and it takes forever to get to that speed. It also will not go over 6600rpm and it also takes forever to get there also. I’ve taking it to the dealership and had them look at it and they said they can’t find the problem. I’m at a loss. Has no check engine light at all. If someone could give me some ideas or has had this problem it would be much appreciated. Thank you Dave.
    • By Marie
    • By SteveS
