I have a Kubota RTV900 that I am having issues with......it will start up, run about 10-15 seconds then die......turn the key off and wait a few minutes, and the same thing happens. I have gone through all the steps listed to bleed and prime the pump even though I did not run out of fuel....and I cracked the lines on the injector pump and watched fuel pump out as I crank it, so I am not convinced that it is a fuel injector issue......is there a relay that could be causing this? What is the starter timer relay that people have mentioned and what does it do?
  • Alex changed the title to Kubota RTV900 won't stay running
I am still not sure about the fuel shutoff solenoid shown in your replay - it engages and moves when I try to start, and then disengages after the engine dies....perhaps it is not opening far enough? What are the relays shown in the attached picture? Could any of those be an issue?
    • By Dennis
    • By Matthew Smith
      2013 Bennche Bighorn 700 EFI
    • By SteveS
    • By Frank Mac67
      - NO CLICK - NO OTHER NOISE
      Can anyone help?
      Can anyone help with this?
