Williams to the Grand Canyon
By Ronald
Check engine light comes on after engine runs continuously for 5 minutes or so. I can shut down the engine and restart and check engine light goes out, then comes back on after running 5 minutes or so? What ya think?
By Mike Turner
American SportWorks LM 650 won’t start at times. Starter won’t engage the solenoid just “clicks” much like a weak battery would cause. Battery was replaced and problem went away and then came back. Replaced positive battery terminal. Problem resolved then returned. Replaced negative battery terminal. Problem gone then returned. Replaced the positive and negative battery cable ends. Problem resolved and now returned. The repair lasts for maybe 12 starts, then the solenoid just “clicks” again as it will with a weak battery. So I replaced the ignition switch. Problem solved for a week. With each “fix” the problem is resolved but only temporarily. Does anyone have any suggestions ? To replace the starter is expensive especially if it’s not the problem.
By Jim D
MSU 500 does nothing when you turn the key. No power to display, fuel pump or anything. Come back a while later and everything works perfect. Starts right up. Battery is fully charged. Could this be the ignition going bad. When it doesn't power up I've found nothinf that will correct it other then waiting and trying later.
By kgs
Got a hisun sector 550 2019 that's got 5900 Miles on it, this year it started to getting hard to start in morning, once I get it started it works good the rest of the day. But to start it in the morning I got to hold the gas pedal to the floor and it will fire up. I replaced the fuel injector but didn't help it. So I just ordered a new air filter and 02 sensor and a maf sensor to put on it to see if this will fix it. Anyone else had this problem. I'm hoping the parts I ordered will fix it. I also bought a new battery to put in it also.
By Byron Johnson
Does anyone have a had time starting there utv.
I have a T-Boss 750 and I have had to put 2 starters in and put heavier wire to the starter but it still has a problem starting. it will turn over and than die before it wil turn over again. could it be that there is to much compression that might cause this problem
Thank you
