Folks:
I live on 11 acres that demands a bit of maintenance, and co-own a large farm a couple of hours away that I hunt on (professionals do the farming).   My mowing/brush control/trail maintenance duties are handled by a 57" rough cut mower (Kunz brand), and I also drag logs and pull sprayers and seeders for food plots and such.
I've been using a  pair of ATV's for decades to handle this work - a 750 for when I need real power (or need both machines at the same time when I have help) and a 500 cc with fixed rear axle for most duties.
Some of the places I need to work are VERY rough, and very three-dimensional, with steep ups and downs and some side-hilling I've learned the hard way not to try with my independent rear suspension 750, but handle with ease with my fixed rear suspension 500.
I've decided I want to sell the 750 and replace it with a UTV that I hope to use as my main workhorse.  If anyone makes a working UTV that fits my specs that's what I'm gonna do.  This is an all-work machine, I don't do any recreational riding so don't care about things like top speed.
So looking for advice on what models might handle what I'm looking for:
Gotta have:
2 passenger (1 row)
selectable 4wd
Power steering
Selectable gearing (not CVT)
Power-assisted dump bed
Engine cooling adequate for all-day slow-speed work in the summertime.  Like towing a 700lb mower at 4mph all day in 100° weather)
Beefy tow rating, including tonque weight.  Nobody ever mentions tongue weight because that exposes how crappy independent rear suspension is for towing safely in rough terrain.
Really want:
Selectable locking diff
Fixed rear axle (Isolates tongue weight from rear suspension.  Holds more stable & consistent center of gravity than IRS over side-slopes and other complex terrain, and keeps geometry and suspension response consistent over wide range of tongue-weight of towed loads)
Slow speed cruise control (
Factory option or aftermarket, covering at least 4mph - 10mph. For calibrated spraying and controlled mowing speed.
Muffler designed for quiet operation for comfortable all-day use, and to minimize disturbance for getting to hunting grounds.  Not concerned about normal motor noise, but don't want something specifically piped to "sound fun".
Any advice on brands or models I'm most likely to have luck with?
    • By Bartender
      Hey Yall,
      I have a 2011 cub cadet UTV that runs rough at higher speeds (sputters) . I changed plugs and replaced the gas with new . Does anyone have any idea thinking fuel filter or pump ?
    • By Smittay
      Looked at a lot of UTVs lately. Couple Questions about Hisun. Some people say they are just cheap with no customer service. Other people seem to have no problems with them.
      Any opinions on Hisun reliability?
      Heard parts are hard to get. Is that true?
      If you had one and didn't like it what do you recommend?
    • By JSmojo
      I've been looking at various types of UTVs in the 400-700cc range. It seems that Massimo has a really good price point but I don't know much about their reliability and availability of parts. Been looking specifically at their T-Boss 550. I've heard the parts might be an issue because the network is smaller, but couldn't find much info from owners.
      Here are a few specific questions about them
      1. In your opinion, are the reliable? Specifically, have you hand any parts break that in your mind shouldn't have?
      2. If you had one and got rid of it, what was the reason?
      3. If you don't recommend Massimo, what would you recommend (even if it costs a little more)?
      4. How easy is it to find a place to service them? How easy is it to get parts if you want to service it yourself?
      If you have any other advice, I would appreciate it. I'm also looking at the Hisun Sector 550.
    • By Rusty Beavers
      I'm working on a Coleman UTV 400 that has a rough idle, owner has had it for about a year. When I say it has a rough idle, it doesn't have the continuous smooth running sound. At times you can hear it kinda skip, sputter, or like the RPM has fallen (RPM stay constant according to the gauge) It's not as bad as it was after I replaced the fuel filter and fuel injector (both are Chiki) not sure if that is a quality brand at this point. Checked the spark plug, it was a little foul, but not too bad. (Since the engine is still idling bad I'm going to replace that) Cleaned the throttle body making sure the carbon and soot has been removed, and the air-filter has been cleaned. New fuel is being used so it's not old or been standing. They did tell me that they were using non-ethanol fuel, not sure if that would be causing the issue. Next two things I can think of that maybe the issue is the O2 sensor or the valves need adjusting.
      Thoughts and suggestions? Thanks in advance.
    • By johnpeter
      2006 POLARIS RANGER 6X6 700 EFI UTV WINCH AND 454 HOURS On Ebay
      https://www.ebay.com/itm/275864835370?
