I have a Bighorn 500 that I use around the yard to move small trailers and trash. Tried to crank yesterday, no electrical power. Changed battery, checked fuses, turned key, nothing. No lights, no horn or anything electrical. Any ideas?
Well sir, assuming your assessment and troubleshooting is top notch, the next possible issue could be a loose wire.
I'd check the ground circuit 1st.
Follow positive wire to starter solenoid, make sure it is tight.
Follow ground wire to frame, make sure it is tight.
What was the voltage reading on battery?
Did you find the main fuse when you checked the fuses?
Does the neutral light come on?
Yep, after troubleshooting almost everything, finally found wire coming from the switch with a pin hole in the boot grounding out on the frame. It's always the last place you look. Thanks for the info.
    • By Unhappy Kioti K9 Owner
