I purchased this side by side with the following done to it
3" Outkast Lift
6" 45% GDP Portals
22" Msa Rims
9.5/22 (40") Tr-171 BKT
Rhino 2.0 All The Way Around
Dirt Mafia Upper and Lower Ball Joints
Brass Brake Pads
Superatv Front Trac Bars
2 6.5 Kicker Speakers In The Dash
High Lifter Snorkel Kit
Highlighter Front 3" Lift
I recently had turf mode deleted along with snorkel and pinion gear, gear reduction and new bearing and seals.. I keep breaking rhino 2.0's in the rear on the differential side. I purchased the side by side without the trans work done and didn't have many rides done on it before I had the work done. Could it be something the mechanic had done when completing turf mod delete? I dont ride hard at all. Any input would be great thanks
    • By Paul in Wisconsin
    • By Karlibob
    • By Robbie Wyre
    • By gwares
      Price : 2500 EUR
      Everything works and new!
      WhatsApp: +33 758 56 21 59
    • By Brett
