I purchased this side by side with the following done to it
3" Outkast Lift
6" 45% GDP Portals
22" Msa Rims
9.5/22 (40") Tr-171 BKT
Rhino 2.0 All The Way Around
Dirt Mafia Upper and Lower Ball Joints
Brass Brake Pads
Superatv Front Trac Bars
2 6.5 Kicker Speakers In The Dash
High Lifter Snorkel Kit
Highlighter Front 3" Lift
I recently had turf mode deleted along with snorkel and pinion gear, gear reduction and new bearing and seals.. I keep breaking rhino 2.0's in the rear on the differential side. I purchased the side by side without the trans work done and didn't have many rides done on it before I had the work done. Could it be something the mechanic had done when completing turf mod delete? I dont ride hard at all. Any input would be great thanks
    • By NC4wd
    • By shawn b
    • By PossumTruck
      Greetings,
    • By Paul in Wisconsin
      I have a 2023 Tracker 800SX LE that I want to add a sway bar to.
      The service manual shows how to remove and reinstall the sway bar.
      I called Cabela's to try and get the saw bar.   They said they can't get one and the 800SX doesn't have one!!??  Then why is it listed in the service manual?? No answer from them.
      Have any of you found a saw bar that fits and what did it cost?
    • By Kingfish
