2019 Coleman 550 Hard to Start
By tipoblanco
Just purchased the Bighorn 550 explorer,after the breakin period what engine oil and diff fluid are you using?ive read about using a motorcycle engine oil or just a 10w40 blend?and differentials,states a 80/90 gl5,is there something preferred over another?is there a better spark plug than the K6RTC? just want to start out doing it correctly,im a true believer in proper maintenance,thanks for any contribution
By Goat Quilter
We pout new belts cleaned engine and carburetor plugs you name it. Drove down road no problem came back uphill no power won’t go . What’s the issue?
could it be clutch?
By weasel
By Goat Quilter
New belts and engine cleaned and checked carburetor cleaned drove on flat ground fine turned to go up hill lost power wouldn’t go
Could it be clutch issue??
so frustrating this thing has been in shop more than used on our farm.
By jonny L
Went for a nice trail ride for about 20 miles, came back, shut it off, and attempted to go for another ride. The electronic gear shifter will not go into park to start it up. It reads neutral in the park position. Disconnected the battery and reconnected and it now read Park. But, when you put your foot on the brake to start it, it goes right back to neutral. Checked everything that I could think of and decided it has to be the 17 gear position sensor. Not certain this is the issue but I bought a used one on Ebay (could not locate a new one) and will try it. Any other possibilities?
