  • Fire mitigation / slash removal from a 5 acre forested and well-gamble-oaked property.  The previous owners thought as much about fire mitigation as I do about fashion: not much.
  • Snow removal
  • Stump pulling
  • General hauling (rock, lumber, etc.)
  • Weimaraner energy depletion.  Wasn't an original use case, but a nice added bonus.
Experiences So Far
After about 9 hours of use, happy to report that things are going well.  The huge (for a UTV) bed is a serious productivity enhancer.  I can cut and haul soooo much more slash than I used to.  The electric dumping feature is pretty great, too.
I was wrong about the motor.  It’s rated at 24hp, not 25 as I mentioned above.  The power is plenty for my needs.  The torque is noticeable.  The on-demand 4x4 is pretty useful as I experienced when stuck on a steep and loamy incline.  Switched it on and immediately achieved traction.
The front and rear hitches, along with the winch, make this a very handy extraction vehicle.  Tree saver and snatch block setup is a breeze.  I use it to pull gamble oak after thinning an area.  Anything I can’t pull by hand with an extractigator I am able to pull with the winch.  The included winch hook is pretty poor.  I’ll be replacing it.
Overall, I’m very pleased and slightly relieved… while American Landmaster has an A+ BBB rating, those ratings aren’t a good indicator of overall quality.
I’ll report back after the first experiences with plowing.  The performance in cold conditions remains to be seen.  Hoping the hydraulic plow I purchased is worth the dough.
Until then…
First snow of the season came Saturday and it snowed through the night into Sunday.  We only accumulated about 10 inches on the deck and 6 on the driveway.  The temp was 8F when I turned the machine on and started plowing.
This was my first time plowing ever.
Observations
  • No problem with the battery in that temp.
  • Plenty of power.
  • Great traction on my asphalt millings driveway.  Doubt I'll need chains.
  • The controls for plowing are decent, but not conducive to multi-tasking the operations of plow up, plow down, switch from FWD to RVS, and steering input.
  • Working the pedals with insulated boots on is a poor experience.
  • The hydraulic plow from Landmaster is beefy and laying a long stripe is very effective.
  • It's much warmer sitting in the cab, even without a heater or doors, than walking behind a blower.
If I had to choose between plowing and snow blowing 6 inches, I would choose the blower.  When I get over 12 inches, I will turn to the plow.
Cheers.
p.s.  If you look closely, you can see I replaced the winch hook.
How are your brakes performing?  I just got my Amp Untamed crew last night and there is almost zero brake pedal travel.  They work but you really have to stand on them.  Wondering about how easy that is going to be in big winter boots.
In racing terms, I would describe them as soft and vague.  Nobody is going to be doing threshold braking effectively with these, but obviously not the intended use.  It seems like my experience is on the other end of the spectrum from yours.  That is interesting, perhaps I will bleed them to see if they perform better.
From a slightly different perspective: on a steep incline, the e-brake only works to keep the vehicle stationary if pulled 100% (all the way to the plastic molding).
I’m seriously considering this same American Landmaster AMP with the long bed.  Would really appreciate any updates you might have, both good and bad experiences.  I have lots of forrest undergrowth to clear and trails to make, plus daily trips up and down 1/4 mile driveway between mailbox, barns and house.  Thanks.
Nothing new to report.  I still think it's excellent and capable.  Now it will be the test of time and how reliable it remains.
I may update the winch with Warn's top UTV / ATV winch to get ~ 2,000 lbs more pulling power.
  • 4 months later...
Any updates would be appreciated
Thanks for the reminder.
So after a winter I’m still very bully on the rig…
There is one issue with the plow accessory that is disappointing: it comes with two holes drilled for the hitch pin and cannot be fully inserted because it hits the front differential.  Pretty dumb design as it also stresses the wires that control the plow functionality when you can’t insert it all the way.  Nothing a hacksaw can’t solve, but it’s a very odd miss.  Perhaps due to supporting multiple models.
On the upside, I left it out all winter uncovered and we received various amounts of weather, including 32 inches of snow.  The thing was covered inside and outside with snow.  It started right up.  It’s also kept a good charge over the winter.  Landmaster told me I could leave it uncovered without issue and they were right.
We are very pleased with the purchase and love the lack of exhaust sound and smell in our quiet area.  Our neighbors saw me running it and told us later they were confused by why they didn’t hear sound out of it.  It’s pretty great, if I have any issues, I’ll report here.
  • 5 months later...
I have a 4x4 AMP with Untamed Edition. The manual mentions a Navitas app for troubleshooting purposes. But I found out that this was discontinued and the new motor and controller to not have an app that people can use, only dealers have access to it. I'm wondering if anyone had to work on their UTV's and wasn't able to do so due to lack of ability to diagnose the trouble codes and was forced to take it to the dealer?
    • By Brent C
      Hi all, I own two Axis UTV's. Last year I purchased a 2022 Axis 500. I had a mechanical issue with the shifting forks after only 50 miles. I contacted Axis/Hisun warranty dept. That were very helpful and willing to send out a representative to see if it was a warranty issue that fell under coverage.  Since I live in an area that does not have authorized repair facility within 300 miles. A really nice guy drove all the way from West Virginia which was 4 hours away. He determined that the console would not stay seated in position and while driving it, the console would jump forward and knock it into the wrong gear causing the shift forks to become bent. It was then picked up a few weeks latter to be repaired in Richmond, Virginia. It should arrive home soon.
      Now to my question. After the 2022 Axis 500 was taken for repairs, I bought the 2024 550 Axis. I bought the first one to take my son who is disabled from an extremely rare disorder that requires daily care to get out of the house. There are two things that give him joy, music and going for rides.  That is why I purchased the first one, However because it had bucket seats and the engine was between the two and was too loud even though I deaden the sound and put a quiet muffler on it.
      I then decided to purchase the Axis 550 for the great updated features and the bench seat, I will be buying the complete enclosure ad on's offered by Hisun. Since it does not come with a heater (Axis 750 does) I was wondering if anyone knows what heater is part of the 750 edition. There was a photo that showed a Firestorm brand, however I can not find what variation it is. If anyone knows what a Inferno heater would be correct for the Axis 550. I would like to install it this Winter to take Justin riding on the farm. Any help would be greatly appreciated.   Brent
    • By JDawg
      Help...
    • By SouthernGypsy
    • By Ductking1
    • By JOSEPH LAMAR
