UT400 - Ran out of gas, cannot restart
Kenbaz
Well, the subject says it all!  After the motor stopped, I went out and bought gas and filled the tank.  Tried to start and it just cranked - no fire. I assumed I had spark, because nothing changed there. I pulled the plug and could not smell gas. The plug was dry. Put it back in and tried to flood it by piumping the pedal, but it was still dry when I  took out again.
   The gas gage red fuel lights didn't seem to recognize that I filled the tank (see previous fuel Haugen posts).  Disconnected and reconnected the negative battery terminal hoping it would reset any interlocks that might be set. Now the ignition panel will not light up when ignition turned to "On".  Things are getting worse instead of better!  Have the fuse panel open, will check fuses tomorrow. Can anyone help me get back on track?  No shop here in Tucson will work on it!  Nice unit. But you're on your own for maintenence. Thanks for any help!
Day 2 Update:  Went through all the fuses today. The fuse for the instrument cluster is not only blown,  but keeps blowing as soon as I turn the ignition to "On".  The only wire bundle I am unable to see is the one from the gas tank that probably goes to the fuel gauge.  I should mention that we live in a rural area and have Prarie dogs and packrats. The sxs is full of pea pods!  Lots knows what they've chewed.  Thank you for advice or sympathy...
Thanks for your reply!  We found the problem after removing the drive shaft tunnel cover and floor panels. Pack rat had totally chewed the electrical lines coming from the gas tank to the instrument panel. Also totally chewed thru the fuel line. Fixing connections should remedy problem. Thanks again.
Slowly getting things fixed. UTV sits outside,  and although it's shaded, it's still hot out for a 76 year old guy (mid-hi 90's). Will have new fuel line hooked up by tomorrow,  then have 4 wires to add new lengths of wire - 8 solder joints. Then reconnect battery and start 'er up.  Fingers crossed...
    • By Bobby Courtney
      I have a 2021 Coleman 400utv with 60 miles on it. I bought as project. It’s idled ruff and fouled plugs since it was new. I have removed and cleaned throttle body new injector new idle air valve new oxygen sensor. Installed ngk iridium plug. Starts and run good for about 5 or 6 miles and fouls plug. It runs rich all the time. I’ve done reset on ecu. I’m about to think it’s time to try a new ecu. Anyone please help.
    • By onealmck
    • By diamondjfarm
      Thanks.
    • By jcbigg
      When I try to start my AXIS 500 (from Lowes) there is a buzzing sound coming from the battery compartment and it will not turn over/start. The battery is showing 12.47 volts so that does not appear to be the issue, are there any suggestions on where to look next?
    • By Jason S
      Good afternoon,
      I have a 2022 Bobcat 34XL.  Over time, I have to press harder and harder on the brake pedal before the ignition will fire. Now I have to practically stand on it with all my weight to get it to start.  Does anyone know if there is a spring or something that might need replacing, or have had this issue before? I don't have any schematics of the brake sensor/assembly.
      TIA
