Starter for 2019 Massimo Buck 400
Go to solution Solved by Howard B,
  • Alex changed the title to Starter for 2019 Massimo Buck 400
Thanks, Howard. I called Massimo direct today. The tech guy said call Partsboss because Massimo corporate didn't have the part.  Okay  so I called Partsboss. They said call Massimo. I said they told me to call you. They said, oh, we are not handling Massimo parts. Sooo, that was how my day went. Howard, if your dealer has my part  let me know, I will have you Knighted in the Kings Court. Remember folks, this is a 4 year old vehicle.
Hi Mitch, Howard here, I talked to my tech, go to the website I gave you yesterday and go to the 450 buck, it should show you all the schematics, go to electrical #2, it'll be called a starting relay(solenoid) that's what you'll need for your massimo. 400 and 450 are the same, except bore size. the rest is all the same.
    • By Joe Breaux
    • By Marie
    • By SteveS
