Not sure what you’re calling low beams. Are you referring to the bottom and middle switch positions?  Agree that that setting is useless. Would like it to be a 3 setting switch so there was an actual “off” setting.
Found out that there are no low beams on the tboss 550. You can purchase an insert from massimo that will fit in the blank spot and can be connected to existing wiring under the hood. I’m not going to worry about it since I bought two lights and have them mounted on the bull bar. Works fine.
    • By Unhappy Kioti K9 Owner
    • By Xov
    • By SpaceGhost
    • By Robbie Wyre
