2011 Polaris Ranger RZR EPS, RZR S, RZR INT'L Service Manual
By kadams428
Recently my four wheeler has had an issue of being set in gear and it begins riding on its own (up to 3-4MPH). It also is having difficulty shifting into different gears after riding in one gear (i.e. going from reverse to high gear). It will shift perfectly fine when shut off, but consistently has both issues stated above.
Previous research has shown me that it could be an issue with belt tension/deflection, however I have been unable to figure out how to do that with these machines. I've seen some clutches have a jam nut and all that is needed is a wrench and an Allen key to make adjustments, but I haven't seen/found that on the 600 clutches. Has anyone done this in the past or have knowledge of how to accomplish this?
By Hunterman22
This is the 2020 updated version from the previous 2009 version. I do not know all the differences. I do know the 2020 models have throttle body , idle air control valve, & idle control sensor.
HS700UTV-4/HS500UTV-4 Hisun Axis 500-700 Service Manual
By JimS409
I picked up this Hisun 700cc for a good deal. no crank no start unit 1900 miles on it. Put a new battery and starter solenoid fired right up but sounded rough some kind of rattle/clunk noise. Does anyone know what this noise could be? Couldn't get a better video of it running as i don't want to risk doing more damage. Drained the oil it looks good no metal in it.
445374820_7315077208620291_6073155782020130975_n.mp4
By htrotte
#1 While troubleshooting an issue with temp warning light I discovered another temp switch mounted in the pipe going to the head The two switches are literally 6 inches apart. Does anyone know what this third switch is used for? If i can figure out how I will post pictures.
Author #2 Finally got the pictures took. See the photo and tell me if you know what the switch on the right is.
It looks to be factory and I know the girl who bought it new and she didn't install it.
I can't find anything on it in any manual i have looked at. Any help would be appreciated.
