I have a 2021 Kawasaki Mule 4010.  I need more ground clearance so I'm looking at 2" lift kit and bigger wheels/tires.  Does anyone have experience adding these items to this model Mule?  Any problems? Suggestions?  Thanks
  • Alex changed the title to 2021 Kawasaki Mule 4010 lift kit and bigger wheels/tires
I havent personally done mods to these models but having worked on them the mule is lacking in the Horsepower department.
Adding larger tires, especially anything more than 1" over stock will definitely require a clutch kit.
Also remember that a lift only raises the center n bumper of the utv, tires create axle/diff clearance.
If you can fit tires without lift, this is better for the axles n suspension and center of gravity.
Best bet is go 1" over stock no lift no clutch kit n go.
    • By UTVLover253
      What you love about it
      What frustrates you
      – Adam
    • By Unhappy Kioti K9 Owner
    • By ToughLuck
    • By Paul L
