Would like to let everybody with the 23' Z Force units know that Spring Brake Thingy now has a parking brake available for these units. Pretty easy install, the brake pedal does need to come off for a couple holes to be drilled, but that's not all that difficult.
These are all made here in the states, like all of our other models.
see it at:
http://springbrakethingy.com
Mods: if we need to do something as a vendor please let me know, couldn't find any info and don't want to brake any rules......
    • By staind
      thanks Dan D. aka staind
    • By SpaceGhost
    • By GaryC
       up.
