2016 Dominator 1000, battery red light, and jurky power steering.
Ok, battery was original, replaced it yesterday with a new one, fully charged ant went for a spin, noticed the red battery picture on the dash screen, also after 10 min drive, the power steering was jerky, like it was cutting out. I am thinking the unit is no charging when the unit is driving, should not have a light with a fully charged battery out of the box. Any suggestions, on what to replace ??
Register a new account
Sign in
      Have an issue all the sudden where the UTV will cut out randomly mid range throttle and under load.  Light consistent throttle on fairly flat ground no problems.  If you quickly change throttle position sometimes it will bog down and cut out, splutter, etc.  Floor it or let off and it may do just fine.  Going up a hill and adding more throttle as the incline demands, will cut out splutter and smell unburnt fuel.  So far doesn't ever completely quit.  If you let off it will idle just fine.  A lot of times if you floor it, it will pick up and even get a boost of power.  Changed to a slightly hotter plug to see if that would make a difference, but it didn't .  Any ideas what might be going on and what to try next?
      Hello All...
    • By Cletus
    • By Tarak1980
    • By Rainman
      Thanks in advance ...
