Need some advice about procedure to remove and install CVT belt on RTVXG-850
After a few days of heavy rainfall I got in my Sidekick and noticed that the belt seemed to be slipping as I was making my way out on a large property.  I turned around and could barely make it back to my shop.  After removing the cowelling I noticed about a quart of water drained out.  I dried the area, the cover and checked the belt.  No signs of dammage, belt looks great and no foreign debris other than water in the area.  I put it back together and there was a definite improvement.  The Sidekick is driveable now but the belt still slips but only at a higher speed and only when the throttle is punched.  I'm wondering whether I may have inadvertently damaged it while it was wet and have ordered a new belt.  I have looked on line to see if there is a guide or procedure, specifically for the CVT belt removal and replacement for the 850 but can find none.  Does anyone have experience with this?
    • By rdborra
    • By Cory J
      Belt started slipping when I used it in high gear. It works okay in low unless I'm trying to power it up a hill and then it slips.., Ordered a new belt and went to change it and found a good bit of oil in the belt housing. Has anyone experienced this? Belt looks fine. Only have 300 miles on this thing..
