I HAVE 2004 POLARIS RANGER 700XP EFI NEED CORRECT FUEL INJECTOR
By weasel
By Sisco
By Off Grid Refugee
I have a yanmar longhorn 6 seater which I believe is having fuel delivery issues. It will run off of starter fluid and will sometimes run on gas but will not idle. Fuel pump is new and verified to put out 56 psi. Injector is new, I'm reading 10.5 volts at the injector, gas is new. The unit will run when the engine symbol is not present at the gauges. Diagnostic port doesn't appear to be present, can't find it where yanmar says it should be. Oil is full but old. Any ideas what's going on here? Is there a maintenance function that will shut this machine down if it has old oil?
By LongSun
By NDV45
I have 2008 Cub Cadet Volunteer Tracker. Was running fine, parked and next morning electric fuel pump inop. Checked voltage had 4.2 volts. Swapped relays in fuse box, checked all fuses (good) and still low voltage. Does the ECU control the voltage to the fuel pump or which relay controls the voltage to the pump?
Have checked all wiring and not found any place it could be shorted (not saying I may have missed something). I am at a loss. Need Help Please.
