I was attempting to pull a log out of the woods and all of the sudden it stopped pulling and made a grinding sound. Unhooked from the log and was able to make it home. Felt like it was skipping, would pull, then skip, then pull. Have I messed up my belt….or worse? Any advice would be appreciated
99% sure the belt would not make a grinding sound.
Were you in 4-wheel or 2-wheel drive?
Kinda sounds like the rear drive shaft.
Kinda sounds like "the cup" and "drive shaft" have stripped teeth.
Look at the pics on a post I made about the drive line on my Axis 500 to see what I'm referring to.
https://www.utvboard.com/topic/10540-axis-500-driveshaft-out-of-transmission/?do=findComment&comment=46068
    • By Bryan g
    • By Greg Kilgore
      I did compression test.
      How hard is it to replace?
      Advise?
    • By mark walkom
    • By TPlummer
      Any ideas on using sound deafening mats? Have they helped with the noise? Worth it? These side by sides are so loud!
