brostar, I will call the add today and find out what dealer they bought the Trooper from. Then we maybe able to get additional info. I will post what I find out.
rocmoc n AZ/Mexico
Hello Brostar,
I have left a voice mail but not hopefully as there was not a message when you call in to the number, just the telco voice message. Sometime this means a scam. I also left an email at the craigslist address in the add. We will see if this is on the up & up or a scam with bad info.
rocmoc n AZ/Mexico
Left or right wheel drive makes me wonder. Does mitsubushi offer a truck with that. I don't see any use for it unless your rock crawling. I suspose one could put seperate brake actuators on to acheive that but that would double the gearing on the un-braked wheel. Locking up one back wheel would be nice for decreasing turning radius. Thought about doing that. I agree, it's all about torque. Don't see any need to go faster.
    • By Bjabbarw
    • By Kingfish
    • By Browner010
      Recently I had an overheating issue on my 2022 Coleman Outfitter 550 (Hisun UT550) and to check to make sure it was fixed I took it out for a ride around the block. After a couple cycles on the LED coolant meter, I took it for a couple mile ride and on my way back I heard a loud metallic snap then a grinding noise. It was still able to move under its own power but very slowly. I was about 2 blocks from the truck so 'I limped it home and up onto the trailer. I know I need to tear it apart and look for what broke, but anyone have a guess as to where to start? I'm seriously getting tired of this damn machine! 750 miles on it and already replaced the belt, wet clutch, primary clutch, clutch roller weights among a few other things. Seriously, this friggin machine has spent more time on the lift than on the road. I thought I bought this new because it was from the owner of a tractor supply, but he registered it under the stores name making me the 2nd owner voiding any and all warranties.
      Any Ideas what to look for would be appreciated.
    • By Chas
      When traveling in the 40 mph range and throttle is released machine starts surging instead of a gradual slow down any help would be appreciated as dealer is clueless
