2022 Tracker 800SX Coolant Tank
Go to solution Solved by Adan,
So my 2022 Tracker 800SX developed a coolant leak. Under pressure there was a pin hole size leak which was spewing coolant towards the firewall. Upon removing the tank I discovered it was bulging pretty severely such that it caused a small crack. Has anyone else experienced this? I suspect either a faulty tank or perhaps a faulty tank cap (rated at 15PSI).
  • Solution
Yes, I'm actually dealing with this issue as we speak. I had to get a replacement but won't get here until lake January. I've had this issue for over a month now.
    • By A P
    • By CYJSP2009
      Dear Friends,
      Buy 1 piece: Get 5% discount,
      Good Luck
      Casey / Leaf Asia
      July-07-2022
    • By Gary Odom
    • By carl baney
    • By Jim Kessell
      Hi All
      Jim
