Recently acquired a 21 year old Mule.  The previous owner let the brake master cylinder run dry, and when I flushed the brakes, one wheel's brakes locked up.  I took the wheel off, but cannot get the axle nut off, and there is not enough space to get my gear puller behind the drum anyway.  Anybody had an issue with seized brakes?  How can I get this thing off to replace it or rebuild it?
you'll have to get the axle nut off first. 1 1/16" If i remember right.
the trick to getting the stuck drums off on these 550's is pb blaster,a hammer, and patience. also wouldn't hurt to open the bleeder on the back of the wheel cylinder to relieve any pressure.. spray the PBlaster between the drum and backing plate, let it sit and soak, and moderately tap around the drum, mainly focusing on the area around the cylinder... patience is KEY.
    • By Poppateets
    • By Jacob E freeman
    • By Xov
    • By Greg Kilgore
      This started back in the summer.
      While on a ride with the wife. Applied the foot brake and the pedal went to the floor. Thought the brake pads were gone. Ordered new pads. Removed the wheels to install new pads and they were in good shape.
      So I bled all 4 brakes cylinders. Got thin dirty fluid out. Almost like dirty water. No air. Got a good pedal.
      Then about a month later, same thing, brake pedal back on the floor. Could pump the pedal and get a little pedal back. Bled again and finally got a good pedal. The fluid was nasty like before. No air. And the fluid was topped off in the reservoir before I started the bleeding process.
      Now same thing. Pedal going back to the floor. Reservoir still full. I'm thinking the master cylinder is bypassing. So have a new on on the way and will report back.
      What do you guys think. Could it be something else.
      I used one of those hand operated vacuum pumps to pull the fluid out of the reservoir when I was bleeding before. First time I've used one. And after a small amount of fluid filled the catch bottle. Seemed like the vacuum pump quit working. Had to close the bleed screw. Pump the brake one time. The start the vacuum thing again.
      Again just wondering what you guys think. Using DOT 3 and DOT 4 brake fluid. Whatever I can get at a reasonable price at parts store.
