  • 4 years later...
Ok, it's awhile. New update, installed two large dry cell batteries under the seat. One for the stereo and the other is the engine battery. Installed a relay between then so when the engine is running both batteries charge. I also replaced the stock starter with one from the xtx 1000. Much better torque.
  • 6 years later...
  • 2 months later...
Yes, you must have a battery isolator so that one battery, if it develops an internal short or a bad cell, it won't draw down the only good battery you have left.  If I were to add a 2nd battery (which I am considering), it would be a deep cycle battery specifically for the winch.  Buy a commercial one rated for your expected load.  Easier to install.
    • By Gorj
    • By Grant
    • By Gorj
      I am into five years of ownership of my electric side by side and I am noticing some deterioration of power. Although I measured the voltage at over 49 volts, I believe the batteries are beginning to fail. I charge them about twice a week. Last year the charger went out and I replaced it with a 48 volt golf cart charger.  What has been your experience with the batteries?
