  • Alex changed the title to 2008 joyner renegade r4 800 Ball Joints
  • 8 months later...
    • By SouthernGypsy
    • By Bjabbarw
      My 2021 Odes Dominator 800 bogs down at 25mph and won’t go over that speed. I have changed the fuel pump and it still does the same, it runs and idles fine, it has great reverse speed, but it won’t accelerate past 25mph. Any Ideas?
    • By Nutcase
    • By JOSEPH LAMAR
    • By Texjpr
