Hi all have a issue with non start
 Turns over happily,  can smell fuel when crank and have check the injector is fireing.  The spark seems weak and spraying easy start down the intake it won't even cough. Have checked all wiring and repair some dodgy bits, now thinking the pick up Coil maybe bad . Check the manual and it gives a resistance of 459 to 561ohms as spec, mine is reading 204.
Would this indicate a bad pick up Coil and cause the no start,  weak spark?
Would the lower reading resistance alter the spark timing?
Ready to burn the thing at the moment lol
Thanks geoff
    • By Marie
    • By Marie
    • By Grant
    • By Matthew Smith
      2013 Bennche Bighorn 700 EFI
