Greetings,
  • 9 months later...
Probably too late. But I just installed a cab heater on my Axis 500 that uses hot coolant and a heater core. Just like a car/truck does. The radiator hoses are 7/8" and the barbed PEX 1" fittings fit pretty good.
    • By Greg Kilgore
      Plumbing parts list.
      2 1" x 3/4" x 1" PEX Tee
      1 3/4" PEX ball valve
      1 1" PEX ball valve
      Wide view of the plumbing.
      Kilgore.
    • By Dennis
    • By mark walkom
    • By Pop Bob
      I was reading through an old thread about the woes of the risky ownership of Hisun UTVs. Well, OK. So we all own some problematic machines. But I’ll say this. I’ve owned bicycles, automobiles, snowmobiles, PWCs, boats motorcycles, class 8 trucks, airplanes and a crapload of heavy equipment. Nothing I’ve owned and operated hasn’t broken or needed maintenance. The difference between all those prior items and my Hisun, I feel, is the support (or lack of)from the factory and dealership. That’s where this and other forums come in. We’re all we have! Well, us and YouTube. Oddly enough though, with help I’ve received from YouTube and you guys,I’m actually starting to enjoy crawling through this machine, and screw the factory/dealer. I’ll make this vehicle what they didn’t. And have fun doing it.
    • By Kingfish
