2006 cub cadet pulley system, 4wd Trail 20 hp kohler model 37ac466d710
By lmarkie
Any thoughts?
By Greg Kilgore
By dave pasch
Has anyone trouble shooted this transfer case? Full 12v to switch and case. No action inside case.
Thanks Dave
By mac66
By Ronald
Check engine light comes on after engine runs continuously for 5 minutes or so. I can shut down the engine and restart and check engine light goes out, then comes back on after running 5 minutes or so? What ya think?
