Automatic Transmission for Trooper
Guest Lenny
Rocmoc, I did some checking and I beleive there are at least a couple of transmissions available. Look at this site.
http://www.cheryacteco.com/en/article_list...=11690974580001
I beleive the QR512 is our transmission however it is slightly different, I suspect ours is the same bolt up pattern but has a lower low gear. QR512 is more then likely for an automobile application. The QR512E is more then likely the automatic version of it. If we can find out what american cars use their automatics coupled to small engines, I'll bet a match could be found. I sent an email to Chery fo find out more. If you look at the engines on their site, they have a great 1.9L diesel that could be coupled to their QR631 6 speed Trans. I think you could squeeze it in and have 3 times the torque. Maybe better to just start from scratch and built the whole thing over. In 2007, Chery entered a contract with Fiat to provide them with 100,000 engines per year.
I have this site also and went to a Chery Forum trying to get info for a source. I had no luck. I believe the cars are not available here in the States. I don't know where you would run one down. If I start changing things that much, I will go with Honda, Subaru or someone more USA mainstream. Good luck, this is a tough one!
When I was at Moab; power was not the issue, gearing was. The only place I need more power is in the sand and I'm not in it that often. We'll see how I feel about that after this trip as Rocky Point is going to be mostly in the sand.
rocmoc n AZ/Mexico
  • 3 years later...
Ok, does anyone have an answer to why I cannot shift gears when the temp drops below forty degrees? I know most of you Joyner owners live in the south, so I'm hoping someone traveled to the north and can help me fix this problem. Otherwise, does anyone know where I can get a cheap auto transmission?
First thought that comes to my mind is the fluid.. it get thick under 40 degrees mine get hard to shift in Iowa winter too. I would recommend synthetic fluid in transmission that can tolerate cold tempatures..I'm not sure if trans take gear oil or atf, someone here would know
Anyone with automatic trans for trooper?
I have heard there was supposed to be an cvt for trooper but i never saw or heard anything more. You could try asking klung motors.
I'm also wondering if anyone know of a rebuild kit i can get for the trans later down the road? My trans like to pop out of gear sometimes when i let off the throttle
    • By Randyh79
      Does the transmission share the crank case oil with the engine or does it have its own oil seperate from the engine?
    • By AlaskaTrail
      New to UTVs and recently accuired a ut400 from our local Alaska Commercial Co. and had a questions regarding the transmission fluid. I have had a squeeling noise, sounds like a teapot, that recently started after being driven for a few minutes. The manual says to change the fluid at 500 miles, so I was thinking maybe its just time for this to be changed. Other then that I cannot find any information regarding the type used. While reading through these forums, I seen someone put that the transmission is lubricated with the engine oil. Is this true? If not what should I be using and where can I find the information to change it out? Any input on this would be greatly appretiated!
      Thanks in advance
    • By lonesome_spud
      I am trying to locate a transmission radiator for my 2022 coleman UT400.  I cannot find a parts listing that shows the transmission radiator, so I am not sure what the part number is.
    • By Oldman
      I installed a new GY6 150cc engine in a Bull Dog Pup 200 and when I put it in drive, it grinds for a second and then runs fine.  Works great when i place it in reverse.  Could it be from it idling too high?   Any help would be greatly appreciated.
      Thanks!!!!
    • By mehe
