2014 Case scout xl trans question
By GunnersTacklebox
By Jon Spruill
By Bbicon
I have a 2014 odes 800 dom. I have a wire in the same harness as the fuel pump plug ( just before it ) and it is not connected to anything t has a connector and a little brass connector on the end , I was wondering if anyone could tell me where it goes to
By Paul L
By Dennis
