What Octane 950 HO EX 2023
Go to solution Solved by Joe Breaux,
Higher octane fuel burns slower and prevents knocking and pinging. Also it tends to have a longer shelf life before it breaks down.
If your model is equipped with antiknock sensor you will find a noticeable performance increase with high octane fuel due to automatic timing advance to take advantage of the fuels burn time.
Regardless it never hurts to run higher octane fuel and for the amount powersports equipment burns price is really negligible.
I try to run nothing but premium in anything but my truck... for both performance and incase it sits for a month or more.
  • Thanks 1
    • By strike250
      Matt
    • By Jim Kessell
      Hi All
      Jim
    • By rocmoc
      This is rocmoc/Michael one of the first on this forum when the Joyner was one of the most active topics.  First an update of others.  The earlier members will also remember Lenny and Jeff.  With myself we organized the first Jamborees in 2009-2012.  Sadly if you have not heard we lost both Lenny and Jeff in 2018.    A great loss to the community.  Myself:  Still around but rolled over to Jeep and Arctic Cat Wildcat.  The Wildcat  design still remains me of my old 2008 Trooper.  Doing well as the Last Man Standing but cleaning out the garage.  Found some New and used Trooper parts I will list in the parts section.  Wanted to give you all a chance before I list on Ebay.  As many of you knew Lenny listed a lot of stuff on Ebay.  Will I partnered a lot of the stuff with him and I still have stuff.  Take care and I will check in for message should you want to ride.  Still make it to Utah every other year and am still in Southern AZ.
      rocmoc in AZ/Mexico
    • By se3388
      Steve.............
