I have a Gator 550 UTV with two rows of seats and dump bed. I bought new UTV LED lights for front and back and have mounted them on the roof, no problem
I now need help hooking and running wires from lights to switch.
Does anyone know someone near Millbrook Al that could do this? If so, please give me contact info.
It's not hard to wire them up yourself.
How do you want to turn them on.
I have a single light bar on front bumper. When I turn on main headlight switch AND bright, aka high beams, led lightbar is on. Dim lightbar is off.
I don't have a individual switch just for the led light bar.
Easy to do. Just need a little wire, a relay, some crimp connectors, few zip ties.
If you want an individual switch to control the lightbar. Need the above plus a switch.
    • By Marie
