Anyone know of a US online retailer for the E1 Discover batteries
I've had a battery failure and need one replacement.  The local distributor told me it might take up to four weeks to get one.  I'd like to order one in sooner than that if possible.  Any help would be appreciated.
Thank you for the link.  I have read it in the past and may at some point decide to do the conversion.  My current need is for a single Discover EVGT6A-A that I can order online and have it shipped to me.  This isn't about all the batteries ageing out and needing replacement.  The failed battery was because the connection from the battery to the cable developed a high resistance connection and it literally melted the lead around the terminal and the threaded insert came out.  I have found an "equivalent replacement" on line, but based on the price I believe it to be a lower quality than the Discover.  If given no other option, I may order one and see how it works out.  The Hisun plant in Texas doesn't even have any of these batteries for me to order one through my dealer.
    • By camojay
    • By GaryC
    • By SayHiToRambo
      08 trooper 1100
      thanks!
