Register a new account
Sign in
    • By Troy C
    • By Brett
    • By redneckred
      Can anyone tell me how to get the engine codes to display on a 2012 Bennche Bighorn 700X?  I played with the gauges once and lucked up on this but can't remember what I did.  Will the codes automatically display if there is a code or do you have to cycle through the display?
    • By Fishing Wiskers
      Top speed is 30mph on flat grass ground.  but it will not go up minor hills forward or reverse without a runing start.  If you start at the bottom of the hill machine will stop about 1/2 way up.  I have the engine cover off and you can see the outside of the drive clutch will stop spining., and the engine does bogg down some.  Dosent matter if engine is cold or warmed up.  Seat belts are connected.  Fuel is clean
      I am not sure how to check for codes with this machine,  can anyone teall me how to do it?
      Compression with hot eng is 145,  valves adjusted to .005 with a cold engine.  Dash shows 426 hours
    • Get More For Your Device
    • By TomW
      I took in my UTV and they fixed the no power I was having ( broken  ground wire)  but they told me I would need a new turn signal relay . If you use the left or right turn signal you get a high pitched whine . I need to look to see if the lights blinks but I don't believe it does. I thionk the relay is located in the battery box with the fuses and starter solenoid. Where might I find a turn signal relay . I have done several searches but come up empty . Anyone have this problem before or know where I might purchase a relay ?
