2012 Polaris RZR Robby Gordon Edition
By TomW
I took in my UTV and they fixed the no power I was having ( broken ground wire) but they told me I would need a new turn signal relay . If you use the left or right turn signal you get a high pitched whine . I need to look to see if the lights blinks but I don't believe it does. I thionk the relay is located in the battery box with the fuses and starter solenoid. Where might I find a turn signal relay . I have done several searches but come up empty . Anyone have this problem before or know where I might purchase a relay ?
By TomW
I had a problem 6-8 mo ago when the unit would not start . But you could see power on the dash. The starter solenoid was replaced and it has been fine until yesterday. When I started it up I noticed a high pitched noise coming from under the front. Like a alarmbuzz ..It seemed to drive fine so I went ahead and used it off and on for a hour or so . The noise would not go away . I parked it in the shed and lifted the hood . It seemed to be coming from the battery compartment ( where the new starter solenoid is) I jiggled the connections and the noise changed timbre and then the machine went dead. No power at all . No lights . When you cross the two poles on the starter solenoid ( previously last year it would start and run ) nothing. Checked the battery and it is fully charged . I checked the fuses inside the battery box and they all looked good but I must be missing something. Anyone have a clue what I need to do next to R&R. The closest repair place is 2 hours away in Mississippi . Any help would be appreciated.
By Moos
I replaced the fuel pump, ended up with a couple bad ones. This last one now worked fine for about 150 miles, now only works when its cool outside. (30-40). As soon as we hit 55 degrees, It will not run. Barely starts, runs rough, will not move. Any ideas? Another bad pump? Something else going on? Any help would be appreciated. Thanks.
