Long Weekend plans ??
By Fishing Wiskers
By WCF
Hi Joyner Gang
New to the Joyner group. I'm making long travel for the 1100 Sand viper. I'm trying to make something that will work as well or even better than the RZR Rino etc. At this time the front has 14" travel rear has 16" of travel. Still developing the suspension. comets are welcome. Ask questions and I will get back to the Forum
By Paul Angstadt
Paul
By Alex
This is an interesting read. ADAS is main stream on cars these days. The technology looks to be headed towards UTVs and Off-Road Vehicles.
Potential Motors and CFMOTO USA have announced a new partnership to integrate advanced driver-assist systems (ADAS) into recreational off-road vehicles for the first time.
Sam Poirier, CEO and co-founder at Potential Motors, says the integration of its technology into CFMOTO’s vehicles will set new standards in the side-by-side segment. (Photo: Potential Motors Inc.) The partnership will first see Potential’s tech integrated into CFMOTO test vehicles. The companies will conduct extensive real-world testing at Potential’s purpose-built off-road proving ground in Fredericton, Canada, and CFMOTO facilities.
Source: https://powersportsbusiness.com/top-stories/2023/12/19/cfmoto-and-potential-motors-announce-industry-first-adas-technology-for-ohvs/
By diamondjfarm
Thanks.
