2012 Polaris RZR Robby Gordon Edition
By Troy C
By redneckred
Can anyone tell me how to get the engine codes to display on a 2012 Bennche Bighorn 700X? I played with the gauges once and lucked up on this but can't remember what I did. Will the codes automatically display if there is a code or do you have to cycle through the display?
By Fishing Wiskers
By TomW
I took in my UTV and they fixed the no power I was having ( broken ground wire) but they told me I would need a new turn signal relay . If you use the left or right turn signal you get a high pitched whine . I need to look to see if the lights blinks but I don't believe it does. I thionk the relay is located in the battery box with the fuses and starter solenoid. Where might I find a turn signal relay . I have done several searches but come up empty . Anyone have this problem before or know where I might purchase a relay ?
