  • 6 years later...
Hello
I can't log in had do a new account Silverbullet10 For you guys with turbo charger this might work better for more power.We built it to work on our supercharger.It works like this.The new maff sensor will tell when there is more boast and ad more fuel as the boast gets higher it will add more fuel to match the boast.It not all or nothing you can run Water alcohol injection or just gas.
Jeff If you can fix i would appreciate it.
Hello
sent you a PM
    • By Marie
    • By Grant
    • By Frank Mac67
      - NO CLICK - NO OTHER NOISE
      Can anyone help?
      Can anyone help with this?
