2016 Hisun 500 turns over,no start
By Matthew Smith
2013 Bennche Bighorn 700 EFI
By Flanman55
2007 Hisun HS700 will not crank. Replace the ignition switch. Same thing. Replaced solenoid by the battery same thing. Can jump it and it starts good across the solenoid posts. Ran a jumper wire from switch to solenoid. Nothing
