    • By Jr Perez
    • By Jerrys500
      Thanks Jerr
    • By JimG
      Here's my question:  Those who use their UTVs with towed drag implements or snow plows, have you noticed any issues with early clutch slippage or failures?  Or premature belt wear?  Other drive line issues??
    • By Duncan
      I got a utv from lowes it has one tire in the back that is the same size as the front tires so it has 3, 26-9-14 and 1 26-11-24. i want to change the rear tire to the same one as the other.So instead of buying a new rim will a 26-11-24 tire fit on a 26-9-14 rim.
