Need manual for teardown and rebuild 2011 hs 500
By tipoblanco
Just purchased the Bighorn 550 explorer,after the breakin period what engine oil and diff fluid are you using?ive read about using a motorcycle engine oil or just a 10w40 blend?and differentials,states a 80/90 gl5,is there something preferred over another?is there a better spark plug than the K6RTC? just want to start out doing it correctly,im a true believer in proper maintenance,thanks for any contribution
By Mike-Tatum
I have a broken item I’m trying to find the name for so I can order a new one. The gas line goes to the fuel injector. What is the piece that attached the fuel line to the fuel injector; “Y” shape.
Mike
By mac66
By Hunterman22
This is the 2020 updated version from the previous 2009 version. I do not know all the differences. I do know the 2020 models have throttle body , idle air control valve, & idle control sensor.
HS700UTV-4/HS500UTV-4 Hisun Axis 500-700 Service Manual
By sxr951
