Just wanted to know of those of you that have changed out their plugs have you replaced them with the Iridium type as what is original or gone to the standard type plug.If you have switched to another type have you noticed any change in performance?
Are you saying that the Iridium type is standard? if so, I'm impressed. They lasted over 90,000 miles in my GMC Yukon with a 350 in it.
kinarfi
kinarfi
No what I meant as standard was the regular type spark plug,I refered to the Iridium as the original or plug that was in the engine when I purchased the vehicle from dealer.Sorry if I made this more confusing then intended.
Have not seen a post of anyone changing plugs. On a positive note, even standard plugs last forever now days with lead-free gas unless you wet the plugs because of an engine problem. Will be very interested in what you do and if you are having problems with your factory plugs. Good luck!
rocmoc n AZ/Mexico
rocmoc n AZ/Mexico
No problems,I just decided to pull the plugs to take a look at them and to be honest that was the first time i had seem an Iridium plug(guess i gotta get out more) and was surprised.I then checked with the Part,Pieces folder Kinarfi has and saw that they are listed as replacents from NGK.Not being familier with them is why I was asking.
    • By Unhappy Kioti K9 Owner
    • By Gorj
    • By mcraigchr
      Howdy y'all,
      Craig C.
    • By lincolnsq175
      I have a 2020 coleman ut400.
      Any info is appreciated.
