Only stays running when I throttle it dies at idle Colman 400 utv
By Unhappy Kioti K9 Owner
I own a K9 with 50hrs that has been in for repair more than once the farm. Multitude of issues, trying to file lemon on it but interested in knowing if owners are organizing for a class action suit. The dealer informs me there are “a lot of owners very unhappy with these”.
By Prepper
By ToughLuck
By CSM_Retired
Greetings All,
By aefron88
