Hey all!
I'm on a mission to buy my first UTV soundbar as a gift for my dad. I'm aiming for something that offers great sound quality without breaking the bank – my budget is around $250. Right now, I'm considering options like ecoxgear, kemimoto, and boss.
Does anyone have experience with these brands or specific models that you'd recommend? Any advice or suggestions would be super appreciated!
Thanks in advance for your help!
Hi Kalyla,
I have a brand new BOSS BRT17SLR in the UNOPENED factory box. I will sell for $160.00 ($150 unit, 10 shipping) Good unit! I've owned one before.
https://bossaudio.com/products/791489132046?variant=48798040129696&currency=USD&utm_medium=product_sync&utm_source=google&utm_content=sag_organic&utm_campaign=sag_organic&tw_source=google&tw_adid=&tw_campaign=20742584627&gad_source=1&gclid=EAIaIQobChMI7cXdsPH9hAMVNTfUAR1xfANdEAQYASABEgJzU_D_BwE
I ended up going with the BOSS BRRF46A. It ROCKS! You can see it in my profile.
-----Blair
    • By Jim Kessell
      2005 American Landmaster
      EH65 Subaru Robins
    • By Paul Angstadt
      Paul
    • By diamondjfarm
      Thanks.
    • By FGT
    • By Mike Turner
      American SportWorks LM 650 won’t start at times. Starter won’t engage the solenoid just “clicks” much like a weak battery would cause. Battery was replaced and problem went away and then came back. Replaced positive battery terminal. Problem resolved then returned. Replaced negative battery terminal. Problem gone then returned. Replaced the positive and negative battery cable ends. Problem resolved and now returned. The repair lasts for maybe 12 starts, then the solenoid just “clicks” again as it will with a weak battery. So I replaced the ignition switch. Problem solved for a week. With each “fix” the problem is resolved but only temporarily. Does anyone have any suggestions ? To replace the starter is expensive especially if it’s not the problem.
