ECU comments - moved
By mcraigchr
Howdy y'all,
Craig C.
By Tejun
By Greg Kilgore
Got a 2021 Axis 500.
Manual states 38nm.
Anybody got the answer?
By camojay
1400 miles on it
20240817_133539_1.mp4
By GaryC
Unfortunately my rear Diff housing cracked on my 2013 and I need to replace it or find a good used complete differential. I think the same one was used from 2013-2016? Any help or referrals appreciated. Thanks, Gary (949)370-2575 (in UT)
