Shot of the week updated
By Red Good
Serial # a8mv86futja001002 , no search engine will give me a model , it has a 471 engine . Is massimo always hard to get hold of ? No answer to emails or phone calls ?
By sxr951
By Steve B
By donny
By Alien10
