Have you tried resetting the ECU? Likely something funky happened with the IAC settings or the fuel trim.
When running rev it to redline in neutral, and shut it off with the pedal still floored. Wait 5 seconds and then let off the pedal and restart as normal
...or you can use the codescanner method if you have the codescan cables and HUD ECU hacker
  • 4 months later...
i bought the plugin connecters that you mentioned or the hisun 400 utv 2020. and the 6 pin plug was different so i had to cut the plastic housing away for the pins to plug in.and i get no readings or power through it. i looked on amazon or the right one but cant find it.if someone can help of were to find the right one would be great.have the hud hacker and everything else its just the plug to the bike?
I am curious Does the 2008 Cub Cadet Tracker have this chip in the ECU?  How do I go about checking codes in it, does anyone have an idea please.
got mine off ebay, should not require any cutting if you get the right adapter.
Mine came slow boat from China, but there were domestic alternatives there for more money.
If I had to guess a model that old is likely carberated, and would not have the Delphi ECU.
Sometime in the mid/late teens is when Hisun switched to fuel injection/Delphi ECU system
  • 4 months later...
    • By Ed Michael
      Subaru SxS.mp4
    • By Some random dude
      2015 Hisun 700 Utv
    • By Sando
