Coleman 400 UTV fuel issue
By corkie
I have replaced the fuel pump assembly 3 times in the last 3 years. The motor always goes bad and will not come on when you turn the ignition on. Anyone else having this problem?
I have a Hisun utv 500.
By Bobby Courtney
I have a 2021 Coleman 400utv with 60 miles on it. I bought as project. It’s idled ruff and fouled plugs since it was new. I have removed and cleaned throttle body new injector new idle air valve new oxygen sensor. Installed ngk iridium plug. Starts and run good for about 5 or 6 miles and fouls plug. It runs rich all the time. I’ve done reset on ecu. I’m about to think it’s time to try a new ecu. Anyone please help.
By onealmck
By Sisco
By diamondjfarm
Thanks.
