I managed to scrounge up enough pads to replace the rear brakes on my Trooper. They went on with no problems, after I figured out how to do it, DUH!
If you haven't done it here is the sequence I used.
1. Jack up rear end and put on jack stands.
2. Remove wheel
3. Remove calipers from backing plate. 2 bolts each caliper
4. Remove the Allen screw that's visible on one side of the caliper. Don't do anything with the side with the rubber cap.
5. Place the caliper on something solid, like the swing arm, and tap the rod that's under the Allen screw IN toward the Allen end. You don't have to drive in all the way in, just far enough to remove the pads from the caliper. You' ll be able to remove the pads before the rod is flush with the caliper edge.
6. Install the new pads - may have to pry the pads apart to clear the disk.
7. Reverse the process
8. Pat yourself on the back
9 Now do the other side
Have fun!
Gumball
Gumball.
I know you had been asking about where to get the pads, where did you find them? might help the rest of us in the future.
I have 40 pads in stock for the troopers and have found another US supplier for them
Jarrad
Hi Rick,
I got some pads from Joyner before they closed. I didn't get a full set so I'm looking for another set.
I got a call from Glade and he's ordered some from the factory. You can find his number on my earlier post. He will call me when he gets them.
In the mean time you can get pads from Jarrad at No Limits Powersports. He has them in stock and has found a US distributor. Hi number is 817-695-1151.
Hope this helps,
Gumball
    • By tskm
      Tom
    • By TPlummer
    • By Greg Kilgore
      This started back in the summer.
      While on a ride with the wife. Applied the foot brake and the pedal went to the floor. Thought the brake pads were gone. Ordered new pads. Removed the wheels to install new pads and they were in good shape.
      So I bled all 4 brakes cylinders. Got thin dirty fluid out. Almost like dirty water. No air. Got a good pedal.
      Then about a month later, same thing, brake pedal back on the floor. Could pump the pedal and get a little pedal back. Bled again and finally got a good pedal. The fluid was nasty like before. No air. And the fluid was topped off in the reservoir before I started the bleeding process.
      Now same thing. Pedal going back to the floor. Reservoir still full. I'm thinking the master cylinder is bypassing. So have a new on on the way and will report back.
      What do you guys think. Could it be something else.
      I used one of those hand operated vacuum pumps to pull the fluid out of the reservoir when I was bleeding before. First time I've used one. And after a small amount of fluid filled the catch bottle. Seemed like the vacuum pump quit working. Had to close the bleed screw. Pump the brake one time. The start the vacuum thing again.
      Again just wondering what you guys think. Using DOT 3 and DOT 4 brake fluid. Whatever I can get at a reasonable price at parts store.
    • By Gary T
