  • Alex changed the title to 2022 Massimo T-Boss 550 No brakes
    • By Frank in MI
      Found a NEW 2022 Bighorn 550 DX for $9K.   Any opinions on this machine????
    • By Rick A
    • By Cletus
    • By TexAcoon
      I'm looking to purchase a 2015 Massimo 550 that might have an issue with it's throttle position sensor.
