I have a DesertCross 800 that doesn't want to stay in low, it pops out when I let off the gas. No problem with the other gears. What do I need to do?  Thanks.
  • Alex changed the title to ODES DesertCross 800 Low won't hold
    • By GaryC
    • By SayHiToRambo
      08 trooper 1100
      thanks!
    • By Troy C
